Home/
Author Mohamed Ali
Summary7 min read
    • Our example: Creating a workflow when a new file is created in SharePoint
                  Co-author: Rob Koehler
                  Already, fans of Microsoft Power Automate (previously called Flow) will know that it’s a great tool for streamlining repetitive tasks and making processes paperless. It’s why the tool is such a great fit with Docusign – we’re all about going paperless and automating key tasks, too.
                  • In procurement, a trigger could occur when a tender/project status is changed in a SharePoint list to automatically send an approved contract for execution
                  • In HR onboarding, when a new employee is added, the onboarding pack (personal profile, payroll data collection, NDA, etc) is automatically sent through an approval and signature workflow
                  Step 1: Docusign Setup
                  1. Login to Docusign Admin and make a note of your Account ID (see top left)
                  2. Create an Integration Key, a special key that enables the API-level authentication:
                    • Go to Integrations > API and Keys, and note down the “Account’s Base URI”. We will refer to this as the Base URL.
                    • then “Add App / Integration Key”, note down the Integration Key
                    • Select “Authorization Code Grant” radio button, then click “Add Secret Key”, and note down the Secret Key
                    • Click “Add URI”, and add the following: https://global.consent.azure-apim.net/redirect (this may change as its generated by Power automate, but this initial value will work for now). Please note down this value of the Redirect URI for now.
                  3. Create Custom Fields
                    • Go to Signing and Sending > Document Custom Fields, click “Add Field”
                    • Choose which fields you’d like to add (e.g. signature, name, signing date) and follow the prompts. For example, if you want to add a Signature field, the recommended values are:
                      • Name: Signature
                      • Type: Sign Here
                      • Shared: Tick (yes)
                      • AutoPlace Text: \s{r}\
                  Step 2
                  Step 3
                  Create a Custom Connector
                  Custom Connector
                  Connector name
                  General
                  Input these details below:
                  • Host: Base URL [captured earlier]
                  • Base URL: /restapi/v2.1
                  Upload connector
                  Security
                  DEMO:
                  PROD:
                  Security
                  Create connector
                  Definition
                  Send document to sign
                  Enter these values:
                  Verb: POST
                  URL: https://demo.docusign.net/restapi/v2.1/accounts/\[your Account ID]/envelopes
                  Body:
                  "documents": [
                  "documentId": "1",
                  "fileExtension": "txt",
                  "name": "Doc1",
                  "order": "1"
                  "recipients": {
                  "signers": [
                  "recipientId": "1",
                  "roleName": "Signer 1",
                  "routingOrder": "1"
                  "status": "sent"
                  Send document to sign 2
                  Import
                  Test
                  Test connection
                  Create steps in flow
                  Inputs:
                  • Site Address: - Sharepoint site
                  • Folder id: Folder path
                  Next step in flow
                  Get file content
                  Inputs:
                  • Site Address: Sharepoint site
                  • File identifier: – This is the output from the previous step. Simply select “File identifier” under “dynamics content” on the right pane. See above screenshot.
                  Compose
                  Connector name
                  Input
                  • Inputs: “base64(…)” – within the brackets, go to “dynamic content” and select the “Get file content” (As below). The final function should read: base64(body('Get_file_content'))
                  Add Custom connector
                  Add custom connector
                  Select the Action we created.
                  Connector name
                  Now add the following values:
                  • documentId: 1
                  • fileExtension: txt
                  • name: Doc1
                  • order: 1
                  • emailSubject: Send document for signature
                  • email: [enter signer email address]
                  • name: [enter signer name]
                  • recipientId: 1
                  • roleName: Signer 1
                  • routingOrder: 1
                  • status: sent
                  Note - For these fields:
                  Now save and run it!
                  Author Mohamed Ali
                    Scaling with Docusign: The ISV՚s guide to account cloning
                    Author Abhay Kumar Nelaturu
